1966 Shoulder Belts
206 Views 10 Replies 5 Participants Last post by  foney_email
I’m looking for creative options for installing shoulder belts. Front is a must, rear would be fantastic. I have a post car. Build date is December 1965, so I’m out of luck for factory mounts. Can anyone give me advice on what I have for options?
Am I SOL? Anything I can fab up? Anyone else have a similar situation and came up with a good solution?
1 - 11 of 11 Posts
3
Here's what I did in my '65, just kept lap belts in the back.
See less See more
  • Like
Reactions: 3
That’s just the kind of thing I’m looking for. Can you provide any details? These are fixed and not retracting, right? Do you think where you drilled it’s strong enough to survive should there be a crash? Did you reinforce, or just drill and maybe sleeve it?
  • Like
Reactions: 1
Well I'm hoping the post is strong enough but maybe others can answer that. No sleeve but grade #8 bolts all around with nylon lock nuts at the top so they can swivel then found some bolt caps to cover the threads and they're just cinch belts as retractables have to be vertically in line floor to roof. It's got to be better than just a lap belt.
  • Like
Reactions: 2
4
68 and up models were designed with rear shoulder belts in mind. The sheetmetal in the package tray is reinforced with a large threaded metal plate as a backing. Although the package tray in the early cars is thinner in the area intended for shoulder belts, It wouldn't be to hard to duplicate or even graft in a section of the later package tray.
See less See more
  • Like
Reactions: 1
3
Even If your '66 doesn't have the factory anchor provisions you could still use this location to add your own.
See less See more
  • Like
Reactions: 2
I did this (front and rear) on my '66. Here is the thread:
If your cowl tag has a little round hole punched in it near the bottom edge, that indicates your car's production was late enough in '66 to have the factory front shoulder harness mount (see pic above) in the roof line. Makes this conversion EASY.
Regarding the rear, DO NOT just drill holes in the package tray...it is too weak to hold a belt in the event of an accident. I used these (see below). They are expensive, but come with custom reinforcement brackets that mount to existing holes in the trunk subframe and make this conversion safe. Last thing you want to cheap out on, in my opinion, are seatbelts!
Converted all 4 seats to 3 point belts in an afternoon. Made it possible for my son to ride in the car with me...money well spent!
  • Like
Reactions: 2
But that’s only for hardtop cars, right? I have a post car. Built December 1965. I looked at the cowl tag right away when purchasing and unfortunately, no hole.
Not sure about posts, true…may be different.
If you modify the roof rail you’ll have to remove the headliner to do it. That shoulder mounting point has to be reinforced though, somehow.
they also sell convertible style front shoulder belt kits that mount to the rear window sill somehow. I recall seeing that kid in a mustang forum when I was researching this
the rear kit should work for your car though.
Retro mount
Do any of you have experience with this mount? Looks like I make a hole and this goes behind the sheet metal and gets riveted in. I guess it’s safe…
looks like the Chevelle guys have done this much more often. I may pick this up and start drilling.
Also, do any of you guys know if we need the 8” or 11” plastic sleeve for the buckle? I don’t know if our seats are considered high or low. I have factory bucket seats for 66.
1 - 11 of 11 Posts
