I have a grail that become available, and need the space
This car is well sorted, new McLeod RST clutch, fresh motor all broken in and tuned. The only think missing is A/C.
$28k in complete drivetrain, all PSH docs including protecto plate
No known accident history, no rust issues, windshield is still 1968 date coded, 104k original miles (supported by owners docs and state inspections on past owners)
1968 PONTIAC GTO for sale
Turns heads everywhere
A true 242 vin car GTO, full PHS documents available with the car. Hood tach!
A very clean car, older respray of original Solar red paint (original color). The interior is red with a black vinyl top. Over $28k spent in new Motor and trans and drivetrain installed
Custom Ca black plate "QWICGTO" with tags just paid in June
This GTO is fast, sounds amazing and is freeway friendly with the TKX 5 speed overdrive!
Power steering (new box with quick ratio)
Power (Electric) hydro boost brakes- gives great brake pressure
New IDIDIT chrome tilt steering column (all joints rebuilds with new parts)
Autometer Aux gauges
Alpine stereo with red Sony kick panel speakers (Bluetooth and USB connector)
Motor and drivetrain
Blue Monkey performance 461 Pontiac motor
Edelbrock Aluminum heads with round port (ram air style) ports
Isky Cam
1.60 roller rockers
Forged pistons and rods
SpeedMaster intake
MSD distributor
Holley Ultra HP Carb
Doug's long tube ceramic coated headers
Full mandrel bent exhaust with Flow master mufflers
Professionally Dyno tuned (Carb and Dist fully dialed in)
Cooling system
"Be cool" Aluminum radiator
160 T-stat
Flowcooler water pump
(Runs great on hot days)
Trans and drivetrain
Tremec "TKX" transmission
Balanced drive shaft
TKX 5 speed with overdrive (looks like factory 4 speed)
Lakewood bell housing ($$$)
Brand new Mcleod RST twin disk clutch
Hydo clutch set up with master cyl built into pedal ($650 alone)
Soft easy clutch that will hold the power and drive easy
10 bolt rear (Pontiac)
Billet axles
3.55 Richmond gears
Yukon L/S
High-capacity cover with supports
Tires, wheels, brakes, suspension etc
Willwood 4 piston front disk brake kit
Willwood 4 piston rear brake kit (not yet installed)
New BF Goodrich tires (front)
New Mickey Thompson drag radials rear
QA1 front and rear sway bars
Bilstein front and rear shocks
All bushings, ballpoints and end links replaced with MOOG components
Many extras, a well sorted beautiful classic mucsle car.
(714) 420-1011 call/text with questions.
