Hello, We have a 68 GTO and noticed a slow leak that's just started on the gas tank. We don't drive it, so to put in gas, we usually add a couple gallons now and then with a 2 gallon gas can. We have done this a few times this summer and the tank is probably the fullest it has been since possibly 1974, the last time we had it licensed. Apparently, the reason why it just started leaking. Anyway, it appears the leak is right at the location on the back where the fill tube connects to the tank. I think I can see a very small hole on the tank itself just to the left of where the fill tube hooks in. Can anyone tell me what is the best way to fix a gas tank leak from the outside of the tank without the need to remove the tank and drain out all the gas? I went ahead and siphoned out a couple of gallons and that stopped the leak. Any help would be appreciated. Thanks, Mike
