1968 tid bits for sale
1968 Lemans front valance real decent original 350
no GTO trim holes ... doubbbble bulb turn signals available
and single bulb ... also I may have a pair of nice oem lenses
7028262 Q jet for parts stuck throttle 50
68 choke coils 2 bbl and 4 bbl 67 and 69 also 70 all years
sweet 68 only timing cover correct bolts n split/lock nuts nice plates all threads nice
no pitting stored for 40 years dry 250
68 manual steering brackets pulleys misc
410 coils n coil brackets 288 293 424 coils also
68 dated voltage reg .... also 69 70 and NOS
68 floor shift column real nice original 225 1 year fits 67 too
68 wood wheel ugly decent ole original complete 275
68-72 upper rear fender trims sweet pair and singles
hood latch .... center supports .... front lite harness ... top shroud metal finger gaurd 30
4 row factory ac radiator needs recored ...
LOUD pair of 68-9 horns 68 dates 252 251 numbers 150 shipped
several sets of dated non working cores 68 69 15-65
std idiot lite clusters ... rally dash clusters ... clocks ... tach ... all 68 only ...working speedometer ...
68 heater control ac and non ac .. nice factory std circuit boards .. bulb holders
working 68 only fuel gauge ..
68 dash pad non ac cores 25 ea
68 glove box doors ... lites ... power trunk release ...
power bucket seat track fits 66-72 works ...some extra parts
68 black kick panels ...real nice !! not reproduced ??I dont think ..bolt in ready 250
single pull... also used in some 69 70 tempest with no side vents on pad
68 Knobs a couple 69 pulls also and extra vents available
ac passenger kick panel 20
9790846 ps crank pulley non ac 68-70 50
manual steering stuff pulleys brackets etc
68 door guts and misc wing windows n frames regulators,,, brackets
rear 68-72 stuff also 68 power window set up factory too
68-72 convertible windshield steel frame no rust issues 125
latches and misc...purple gray floor harness 15.00 ..
68-72 rear seat boot bracket ....drivers boot stainless 45.00 ..
visor parts ... rear view convert parts
dash pad light s n lenses courtesy
1 set of sweet wheel well trims 68 69 ... GM 350 ... front single spares too ....
CT drum original master needs rebuilt 35
68 and 69 date coded rear drum pairs ... 1 nice 2 piece rotor GM original
68 front drum Delco Morraine wheel cylinders need rebuild 35 pair
68 Lemans 2 speed shifters n parts 10-75 cables brackets top plates nice chrome
MINT rear window stainless set of 4 upper singles 68-72
front window stainless sets n singles
SWEET GM pair of 1/4 glass chrome trim and seals GM originals MINT 275 soft rubber still
light green 68 only window cranks longs and shorts ..3 rib knob all 75
mint door releases pair 65
front and rear arm rests sweet GM originals black parchment green ask
68-69 front bumper brackets non hidewaway 65 pair
crossmember ,,, correct trans mount hardware ,,,
sweet GM flywheel and bellhousing bellcrank pedals shifter porch
NOS shifter levers 68 67 NOS reverse rod and used ...
3138 MINT HURST shifter box HURST shifter mount
dated oil filter mounts ,,, and heat riser stop tab 67 68 ?
windage trays long and short 20-65 ea
lots of hardware and other 68 stuff ,,, radios 8 track 5 blade flex 4 blade std
fan spacers heater wiring n cables
really nice set of bolt on door hinges 4 225 gm originals shipped
gas door flippers wides and narrows ...
round 68 only not reproduced top rear bumper bracket bumpers 1 each side
68 only rear 1/4 edge lip brackets 2 bolts and nice rubbers with clips 100 pair
69 are different
68 only endura misc ... hideaway and std brackets buckets etc
Scott T
69 are different
Scott T
