Does anyone have a diagram of parking light mounting for a 1969 GTO valance? Also looking for plugs for back of lights.
you must have 1970 buckets if theres a question on mounting ...
as
69 and 70 mount different...
69's have 2 studs on the back and nuts ...
I am pointing to a 70,, they were held in with the lens screw ...holding it all together and the rear bracket was welded to the valance ... that helped a little
Scott
GTO valance
I have a 69 Lemans. I guess I need the fillers? I also need the plugs as the lemans plugs are different.
the plugs should be the same ... you just need to run a ground...
is your valance a gm valance or a repro....
if its an original buy ONLY NOS or very nice GM surround fillers
repops dont fit very well in originals
