googles your friend ....
http://www.hotrodreference.com/862/chevelle-and-gm-a-body-front-suspension-torque-settings most important words first good luck ..............
http://www.hotrodreference.com/862/chevelle-and-gm-a-body-front-suspension-torque-settings most important words first good luck ..............[/quote] Thank you for this. Believe it or not, I did try to google it. I saw that page but as there was no model years listed or referenced, I wasn't sure about it. Chris
UPDATE - I purchased the Pontiac service manual and figured I would update this post just in case anyone else needed the information. The torque specs listed in the hotrodreference page on the first reply do NOT seem to match the Pontiac service manual.
From the service manual it appears they should be:
inner tie rod nuts: 60 fl/lb (85 lbs max to insert cotter pin)
outer tie rod nuts: 50 ft/lb (85 lbs max to insert cotter pin)
adjuster sleeve nuts: 20 ft/lbs
Best Regards
