Thanks Jim, that's all I am working on right now is a plan. The work I plan to do won't be started until next winter when I get my 3 car garage for it. What kind of ballpark price am I looking at to have someone port iron heads?
I don't know what it would cost to have heads ported/polished, but it is not inexpensive. Most engine building machine shops usually can do this. The assorted Pontiac engine builders found on the internet all do this. But.......
Why not do it yourself. This is half the fun. Not very difficult to do a basic intake gasket port match and smooth out the intake/exhaust runners. Now if you want to open up the bowls or do some combustion chamber work, that is a little more work and skill and you don't want to mess up.
Here is a Youtube video on the basic job you can do.
https://www.youtube.com/watch?v=LdSgdX9mprE
You can get a die grinder from Home Depot or Lowe's or any other tool supplier. I use a carbide cutter to remove metal and these can be purchased online or at your local welding supply store or tool store. The sanding rolls can actually be bought in kit form for porting/polishing heads. I bought a kit 30 years ago and still use it. You can usually find sanding rolls locally. Here is a good kit to use that has all the extensions for the sanding rolls.
Engine Porting Kit
You can also get the carbide cutters from Eastwood, but to be honest, for a nice basic port/polish you really don't need them. If you get any, it would be to remove any metal at the port openings to match the gasket, but you can most likely use a sanding roll to do this. Now if you port match your heads to the Ram Air IV gaskets, then you would need the cutter as you are raising the roof a fair amount and then blending it back about 1". I did this on my heads. I also used a "snap gauge" to equalize all my port openings by grinding on the pushrod side of the port -just enough to equalize and not break through and then blended everything.
You can do some heavy head work, but it is not for the faint of heart if you have never done this or don't want to chance screwing up and damaging the heads -like in the bowl area. I never did this before and tried it on my heads -very carefully. I'm no expert, but I think they came out good. My machinist was impressed.
A very good video, which I feel is more aimed at the experienced head porting and polishing guy, that shows you some heavy work done on a Pontiac head is by Pete McCarthy. Click on his highlighted name here -
Pete McCarthy I have this DVD and it is good info on head flow in general, plus head modifications. He also has his book that every Pontiac nut should have in that it gives you head numbers, block numbers, year by year Pontiac engine info, rod/intake /exhaust manifold info and differences and tons of pictures. This is where I get a lot of my info when someone is looking for it.....like your engine ID for example.
A very good book you want to have in your Pontiac collection is the Pontiac Engine Design & Blueprinting by H-O Racing Specialties sold through Ames and can be found in their on-line catalog. Good drawings & references on port designs, head work, and a good Pontiac 3 angle valve job PLUS a ton of other info on the Pontiac engine.
Jim Hand has a book out that most will recommend and is top notch in modifying the heads, cam selection, intakes, etc., but it is no longer in print at this time and getting a copy used seems to be more than the price of an ounce of gold. Hopefully it will be reprinted at some point.
So, do a little homework, do a lot of reading and watch some of the assorted Youtube clips, and get an idea of what you are getting into and if you feel comfortable doing the work yourself. I think it is easy enough to do the basic port matching and polishing, and then add a good set of the Ferrea SS valves, and a good "Pontiac" 3 angle valve job to get a decent street head that will add to your engines performance short of going the racing route and wanting BIG horsepower numbers.:thumbsup:
