Does anyone know if a 1974 Nova instrument panel is the same as that of a 74 GTO. The face appears perfectly similar, but what about the electronics and connections. (Tach/Speedo/Clock from left-to-right). I need a quick answer if you have one.
Injun Don
[email protected]
they were basically the same car so they should fit but as to being the same I am not sure...Pontiacs many times had Rally Gauges at least as an option and the GTO IIRC had an engine turned (plastic) dash plate...
This'll get you to the top and hopefully someone will chime in with your answer...
Bill
