Sixt5 is correct. Not a PowerGlide. Suoer Turbine 300. No amount of modifications can make ST-300 "act" like a 'glide.
Drag racers use PowerGlide in LIGHT cars (under 3,000 lbs.) for best results in bracket racing. Often, 'glide cars are 1/8 mile "specialists". Only one shift... Heavier cars generally use TH400.
TH350 will literally bolt right in. Adding the lower 1st gear changes the entire "character" of the car. It will act similarly on the highway, but low-end performance is DRAMATICALLY improved, expecially when you have "tall" gears (3.23-higher ratio, lower "numerical").
If "originality" is not the primary concern, TH350 for a mild engine and TH400 (needs a bit of "adaption", but well worth it) for a "hot" motor...
FWIW
Jim
I am restoring my '66 GTO Cv for concours competition, so originality is an issue for me. Could the TH200-4R or any other TH have been ordered factory or dealer-installed for my goat w/build date of the 4th week of May? Or were they really 'n truly not available til '67?
I have 3 motors I can put in, a 389 YF (360hp), a 389 YR(, both rebuilt, or a 421 YJ, and 2 Tripower units, both rebuilt. I know no 421s were factory installed, but I've read some were dealer-installed. The YR's DOB was 10/29/65; the YF was born on 08/23/66, and the YJ is a late '66 motor (356hp), as yet not rebuilt.
One Tripower intake manifold is original, dated 11/05/65
I will welcome opinions as to which configuration will work best in concours. I will use a RE ratio that will help the 2spd along, but I wonder if the 3.08 will serve just as well. Thanks for your help in this.
:willy:
