it totally sucks thats my issue . i just traded in my 03 gtp with the bose set up that totally blows this away . any suggestions on some simple upgrading of somekind. and yes the amps due shut down so annoying . help
Don't burn your CDs at speeds greater than 8-16X. That is the solution to this problem with lots of CD players. And I know for a fact it works on the stock Blaupunkt player.skibum100_777 said:does anyone have a problem with the cd player? specifically, does anyone who makes their own cd mixes have a problem playing them in their gto?
i can get my gto to play a burned cd past track 4 or 5. i haven't tried to play an original cd, because i haven't purchased one in maybe 7 or 8 years.
if it's just mine, i need to get it checked out. thanks.
i'll give it a shot, but i think i already tried the slowest write setting on mine. maybe i can find someone that has a slower burner. if i can test a cd that was burned more slowly and it works, i'm sure i can purchase a slower burner for cheap.djdub said:Don't burn your CDs at speeds greater than 8-16X. That is the solution to this problem with lots of CD players. And I know for a fact it works on the stock Blaupunkt player.
i had a stratus r/t as well, and i agree with you. i think the better highs in the r/t (especially in the front seats) are because of the tweeters located right inside the door by the sideview mirrors???fffernan said:My Stratus R/T's Infinity system sounded way better than the GTO's. The bass has no rumble in the GTO and the highs are kind of bland.
-Frank
I use burned cds all the time.I burn them work and at home , both work fine in my car.skibum100_777 said:does anyone have a problem with the cd player? specifically, does anyone who makes their own cd mixes have a problem playing them in their gto?
