1 - 1 of 1 Posts
I have a 2004 Pontiac gto supercharged 6 speed I have lost interest in and selling to buy buy a new truck. Asking 18,500 obo The car has been tuned by pcm of nc and pulls hard. The car is in pretty good condition has been repainted the only thing I haven't gotten around to doing was wanted to redo the seats passenger side has a small hole. Here is a list of the things that has been done to the car and I am sure that I will be forgetting. Have to see to appreciate the work that has been done to the car. Purchased the car in 2017 with 129,889 now the car has 132,378 has clean title. No tire kickers and joy rides.
All seals have been replaced in the motor
New GM lsa supercharger
New zl1 lsa lid
Ported and polished throttle body
X-air otr with x-air filler plate
Fuel injection connection 750cc injectors
Lingenfelter fuel pump with kenny bell boost a pump
Brian Tooley stage 2 supercharger cam with new valve steam seals, double valve springs, titanium spring retainers
Upgraded larger heat exchanger
Lsx innovations upgraded hd belt tensioner setup with hd gates belt
Shorty headers with jba cat less mid pipes and Bassani cat back
Aem wideband with Aem fuel pressure gauge
All aluminum radiator with flex a lite slim fans with mishimoto radiator hoses
Hawk motorsports 7/8 bore adjustable clutch master cylinder
Ls7 z06 clutch and flywheel with stainless line, remote bleeder and Hinson short throw shifter
Driveshaft shop 1000hp one piece drive shaft
Energy suspension full poly bushing kit front and rear
Cx racing 16 way adjustable coil overs with whiteline strut tops
Whiteline radius rod bushings with whiteline sway bar bushings and front and rear hotchkis larger sway bars
Spohn hd adjustable rear toe rods
Ctsv front and rear Brembo brakes new brake master cylinder
Vfn 3" sunoco hood (to clear zl1 lid)
Jhp rear spoiler
Added 06 gto door unlock switch and outside temp mirror
Duel gauge pod for wideband and fuel pressure gauge
Jail broke gauge pod with custom display
New rear diff
bmr skid plates
I am sure that I am missing a ton of things that have been done to it. Feel free to ask question.
Wheel Tire Car Vehicle Automotive lighting
Wheel Tire Car Vehicle Land vehicle
Wheel Tire Car Vehicle Window
Car Land vehicle Vehicle Speedometer Motor vehicle
Tire Wheel Car Land vehicle Vehicle
Speedometer Odometer Trip computer Vehicle Car
Vehicle Car Motor vehicle Automotive design Car seat cover
1 - 1 of 1 Posts
