1 - 9 of 9 Posts
Do you mean the tilt? Lumbar is a mechanical knob you turn. . .
It sounds like you're talking about the seat tilt. That's controlled by a motor and the vertical switch and where that problem would be. The "lumbar" is a big mechanical knob that adjusts the "bump" at the bottom of the seat back in the lumbar region of your lower back.
Ok, u win i wont call it lumbar around u just everyone else. I fixed it thanks.
whoa. You can call it what you want but what are you going to call the lumbar adjustment then? Try reading the manual.
Interesting thread.
1) a plea for help
2) someone tries to help
3) helper insulted
4) problem solved with no "where, why or how" to help someone in the future
Need more like this
Interesting thread.
1) a plea for help
3) helper insulted
Need more like this
A "plea"?? Just threw it out there before I attacked it so I could save some time. If anyone wants to know what I found Ill be glad to help. Sorry you think I insulted the guy, tomaaaato tomooootto
His time is valuable too. He just happens to be a premier member and one of the most helpful guys on the forum. Had it turned out the other way and you still needed help... maybe then you would have a little more patience.
Glad you got your problem resolved.
1 - 9 of 9 Posts
