Check engine light came on today. Ran the code and it came up with P0604.
"Definition- Control Module Random Access Memory (RAM) fault
Explanation -ECM detected the internal data test failed (RAM)
Probably Cause- Failed ECM"
Anyone have any idea what that could be? My car only has 27k miles on it. Id appreciate any advice in case its something I dont need to pay the shop to do.
If it's a failed ECM then you're going to need the dealer. You're going to need a new ECM and a Tech II to connect it up to the other modules. You could try disconnecting the battery for 15 minutes and rehook it up. Maybe it is a one time glitch.
It sounds like the Cardon unit is a reman but I wouldn't be afraid of that at all. Electronics that have been cycled can be better than new untested ones. It has a warranty and if it lives through that it will probably outlive the car.
