Traction works on throttle, spark, and brakes. The only way to make effective traction controll work on high HP and Torque engines is brake intervention. The momentum cannot be overcome fast enough with only the engine ( throttle, spark and/or cylinder fuel shut-off ). So the brakes must "kick-in" first to stop the momentum then the throttle and reduced output mode can be effective to controll the rest of the event. ( Brake intervention is of a very short duration )
