I am putting a '06 interior in my '67. I am modifying the console to fit. Does anyone have a schematic? All I need is to power the compartment light and the 12 volt socket. I do not need to power windows or locks. Not sure which pigtail is the main connector. I am guessing that the yellow is the 12v+ and the black/white is the ground? HELP!:willy:
Yes, you are correct.
Yellow = +12V
Blk/white stripe = Ground
Brown/white stripe = IP lamp power (dimmer controlled)
Use the yellow for full 12V supply to the compartment lamp and the power outlet.
Use the brown/white for dimmer control of the shift indicator light, if you are using one.
