Anyone have a problem shifting from 1st to 2nd? Every now and then my car refuses to go into second, and it is not because of the shift 1 to 4 light, it just doenst like to go into second.
Mine will pop out of 1st if I don't make sure it is pressed all the way. No 2nd gear problems.GTO_Mike said:I have never had this problem but every once in awhile my car pops out of gear when I'm in second. It only does it in that gear at low speeds. Anyone else have this happen? Also, what is the diff between an M6 and an M12?
Bypassing the problem is not going to correct it. IF there is something wrong get it checked. Starting out in 2nd gear is not the answer. If it were, there'd be no 1st gear :willy:I Stall Automatics said:If you have problems shifting into first or reverse from a start, try moving the shifter into second gear, and then trying to get it back into first or reverse... for some reason this works for me... seems like it clears up the gearbox.
