Pulled 326 out of '66 Lemans convertible. Ready to install 455. When I put both engines side by side in the garage, I noticed that the 326 has 2 head bolts on the drivers' side between #1 and#3 cylinders, and between #5 and#7 cylinders which both had smaller studs on top of the bolts for my ground wire and for starter wire tube. The 455 has no studs on the head bolts. Can I: 1) take the bolts out of the 455 4x head one at a time and replace them with the 2 bolts from the 326 w/ 094 heads, or will that compromise the integrity of the new head gasket on the 455? And: 2) Does anyone know if these bolts are the same length on both engines? Need to know asap! THANKS
Discussion Starter #2
455 head bolt
I guess the real crux of the question is: can I remove head bolts one at a time and replace them without compromising the head gasket?
warp the head
Well I reccon there's no good answer, so I'll just do it, and the new head gasket be damned.
you can run the ground cable to the block in any extra hole just sand paint away before you do and put a little dielectric grease on it, for the starter tube you can mount with bolt just be sure to torque it back to spec and you should be good.
