Im looking to put 345/30R18 BFGoodrich g-Force T/A Drag Radials on the rear. I need to find a wheel to fit the rear and have the same type fit the front. I've tryed tire rack and tire discount looking for wheels but couldnt find the right wheels.
Oh for the Love of God!! LOLCopperD said:I dont care about the whole rubbing thing. I have a cutting torch so they will fit![]()
Just a heads up....CopperD said:I dont care about the whole rubbing thing. I have a cutting torch so they will fitI just need to find some 5x120mm rims that are 13.5 inches wide.
The IRS isn't the problem. The problem is the big ass shock tower in your way. The car can be safely tubbed to fit 13 inch wheels without touching the interior. But you have to get rid of that shock in the way. maybe retrofit a wishbone vette suspension to the car.CopperD said:So it seems the problem is with the IRS. Hmmmm I love IRS. I need to ponder this one
A big shoehorn too!GTODEALER said:Just a heads up....
If you really plan on running a 13.5" wheel on the back of the GTO you're gonna need a little more than a cutting torch. You can run a straight axle and tub the rear and maybe get it to fit, but then again judging from your current mods that might not be that far out there.....
