Hi,
I am looking at this nice 06 gto with the t56 6 speed trans. There is a grind when shifting into 3rd at medium to high rpms. Every other gear is fine.
Is this a common problem?
from my experience with manual transmissions the most likely cause of gear grinding would be the syncro's but I have never owned a gto or any gm vehicle.
If a rebuild would be required, can anyone ballpark a $$ amount? I am in NYC area.
But I'll bet is wasn't checked for shimming. Most mechanics assume it's "stock" for that drive-train so they just bolt up and go. The tolerances of the hydraulics are pretty critical.
Park your car on a flat surface and while in gear with the brakes off rev the engine and see if you move. If you even feel it a little the clutch is dragging and possibly needs the slave shimmed. There is a procedure for measuring.
