Working on a street 428 motor going in 67 gto. Rest of car. 4.10 12 bolt posi, m21, headers, 66 tripower. Engine 68 basic stock, 4 bolt, been cleaned up .005 over. Stock pistons, rods, 62 heads. "Rebuilt" before I got it so I took tomachine shop to see what I actually had. All stock except crower cam 60244 and adjustable rocker studs. Kinda weird cam, as specs say it requires 11:1 compression. It seems to have a lot of overlap so thinking they were trying to compensate for the high compression with this cam
So now question is what to do with it. To get 9.5 compression with these heads I get into custom $750 pistons and one recommendation was to do that and go with a comp cam XE268H. This recommendation came from Butler so prob a pretty valid recommendation
Previously I had a similar 428 with the RAIV cam with high compression and like the semi rough idle. I know the RAIV cam is completely different than the XE268H cam and has some overlap but not as much as the crower that's in it now. Guess there is some thought that the overlap actually lowers the actual C.R. A little from the actual calculated C.R?
I don't want it to sound like a SBC sitting at a stoplight. I like the RAIV idle, but also know that's a 50 year old grind and cams come a long ways since then
Any thoughts? Suggestions? Also anyone of any pistons available? I can get flats or up to about 14cc dish which is still prob a little over 10:1. Even those pistons are $600, so not drastically cheaper than the custom ones.
Would be convenient to run pump gas, but not against adding some octane out of a can.
