1 - 12 of 12 Posts
I finally fixed my water pump leak and fired up the GTO for the first time in 2-3 weeks. Idle was off the charts at 1500rpm! Vacuum advance on HEI was blocked off. Backed off the idle screw completely, no change, adjusted timing-no change except when going way clockwise (retard) and still too high, adjusted air mixture screws all the way in and out one turn increments out to 3 turns-no change. I'm thinking at 1500 rpm centrifugal advance has already kicked in and carb is beyond the idle circuit. The 389 has been bored 30 over, a mid range power cam 2000-4600, Edelbrock Performer intake, restored '68 Q-Jet, Hooker Headers, TH400.
Could it be weak advance springs or vacuum lines incorrectly attached? A good vacuum diagram for '68 Q-Jet would be good. Any advice would be greatly appreciated! Thanks!
How is your throttle linkage? The throttle spring. Check for vacuum leaks. I can't see how changing a water pump would have anything to do with the idle speed.
Sounds like a carb problem, not a distributor problem. First, make sure your choke is wide open and that the choke linkage is not set on the high idle side. You should see a screw adjustment for this as well as the fast idle screw - 2 different screws & adjustments if you hav this on your carb. Make sure the cam/arm is not hanging up or not dropping down like it should to kick down the choke and lower your idle speed. Here is a You Tube video:
Sometimes the throttle cable can be too tight and keep the primaries on the carb from fully closing. Quick check would be to undo the cable and fire it back up. If it idles down, then adjust the cable to give it a little more slack.
Wrong carb gasket on the base allowing either the carb to not fully close or allow a vacuum leak. There are several gaskets that fit and you have to be sure you have the correct one. There could also be a vacuum leak somewhere in the intake system, ie the carb, a vacuum line, even a bad intake gasket - all can let more air in and raise idle speeds. I have never done this, but it is said you can use a small hand held propane torch to run it along these various areas to find any vacuum leaks. If the engine speeds up while running and doing this test, you found the vacuum leak.
Bigger cam will sometimes affect the metering rods within the carb. There is a spring found under the power valve - which is controlled by engine vacuum. Less vacuum will allow the spring/rods to be in the raised position allowing a richer mixture, where they would normally be pulled down into their lowered position for a factory cam/strong vacuum signal. They make weaker springs that can be swapped out to match the lower vacuum signal and drop the metering rods into position to run leaner at idle. The top of the carb has to be pulled off to access the spring.
Is the carb flooding? Too high a float setting could be pushing some extra fuel into the carb causing it to run richer/faster.
Retarding your timing should drop idle speed, but retarding it too much will make your engine run hot. Set your timing to factory specs and then do some testing with the carb as it does sound more like a carb/vacuum issue rather than timing at this point.
Good points. I thought at first it could be a sticky throttle linkage but it seems to be ok. The engine was showing 20" of vacuum and have not yet found a vacuum leak but will use propane to confirm. A couple things I did find today was when I took the distributor cap off the rotor button was 180 degrees off... don't know how that happened since the HEI w/vac canister will only allow about 20-30 degrees of rotation. Also, the mechanical advance springs are very weak and do not fully close the arms. I've ordered new springs and will put them in next week and reset distributor to #1 cylinder. I'm still scratching my on this one. Thanks, Roqetman.
PontiacJim, Good advice, thanks for the videos. I'll check choke fast idle cam and vacuum leaks using propane. As I indicated in my reply to Extinctmake, I found the rotary button off 180 degrees when I pulled the cap this morning, don't know how that happened??? Also, the mech advance springs are weak and do not fully close the arms. I'm going to fix both these issues next week and post my findings. Thanks, Roqetman.
Roquetman:
Sound advice from PontiacJim as always. I agree that first thing to check is Choke fast idle cam and choke operation. Once that ok then look elsewhere. Vacumn leaks are possible, but with a steady reading of 20 hg, not the first concern
your Distributor weak springs and losse waits are giving you too much centrifigal timing at idle. You should have no Centrifigal timing at idle and springs should fully retract weights. this clearly additional timing can make the engine run faster.
Try this, remove dist cap and just take off weights and springs. then replace cap and set timing at 10 BTDC or 8 if you like, see what the idle is there if it is better. You need those replaced. Clearly that is wrong.
Weights should only come in above idle? your dist vac can should be disconnected and vac to manifold plugged to check timing?...do you run full manifold vac or Ported to Distributor?
it matters because timing is pulled in there as well depending on vac can...
you will get it!!! hang in there
I'm embarrassed to say this but... I apparently set the dist in the engine at top of exhaust stroke instead of TDC, hence 180 off. I'm installing new springs tomorrow and of course be sure to set dist at TDC of compression stroke and adjust to 10 BTDC. From there I can check for vac leaks and fast idle cam. I'm running ported vacuum for vacuum advance, connected to driver side of Qjet above the throttle plates. As for other vacuum lines. The PB, PCV are connected to directly to manifold vacuum. The transmission vac is connected to rear base of the carb, below throttle plates, is this an appropriate port for the Trans? And the AC vac line is connected to the front passenger side at base of carb. Any advice on vacuum line placement with Qjet would be appreciated. Thanks for everyone's advice! I'll keep ya'll posted.
Roqetman; that will all work ok. The easy xl for manifold vac is just to pull line at carb base at idle and see if it is pulling vac,....then it is full.
I think your Dist being 180 off giving 13 degrees off on timing and loose springs and weights could have been giving lots of idle advance making it run real fast......
Using ported vac assures you will have no vac advance at idle, so for now that is good.
I like full manifold vac to the vac can and pull in more timing at idle, but that is a topic for another day.
Right now you want to get a normal idle and spark, and get her running. Don't be embarrassed we have all done much worse stuff!
Make sure when you set the Dist in that the "dimple" on the rotor gear on the bottom of Dist is in straight up orientation to the rotor tip, sometimes this is missed and also throws timing off. It is an easy visual check if the Dist is out of the engine.
Also make sure you trace at least twice to verify where you think #1 plug terminal is on the cap, that is easy to mix up as well, just make sure.
I know you will get it and your car looks awesome!
Also I wanted to tell you that sometimes weak throttle return spring messes you up and won't close the throttle enough, just make sure that is correct and in good shape, should close throttle strong back to idle....
I want to thank everyone for your advice. Once I got the timing set correctly the idle became tunable. Currently I have the timing at 8 degrees BTDC and idle is 650 rpm. I will probably adjust this a little more as time permits. It now needs a good test drive now and a little more fine tuning. But, I've got to get the interior back in before that, LOL!
Lemans guy, thanks for the compliment on my car! Tell me a little more about vacuum advance being connected to full vacuum versus timed.
Thanks, Roqetman.
R;...Just curved an HEI Dist this morning for a friend, they are all way out of what they should be, even the new ones. Did two different aftermarket ones recently both new and way off.
So do this first get this Vacumn can. It is made by Standard Motor Parts SMP VC 302.....Rock auto sells it as a VC 302....Napa part number is VC 1703, ...O'Reilly sells it as a BWD V482.... about 15 bucks.....Standard makes them all just rebranded. Number stamped on the can is 626 10.
If you have the can with the hex nose looks like it takes a big wrench,....the last two of those I Tested on my distributor machine had 22 or more degrees of timing advance...way too much!...It is adjustable for rate only, as to when it starts and stops from Vacumn, not the amount of timing which is what really matters.
So the can I reference above pulls in 10 degrees timing advance at the crank,....that is the number 10 stamped in it.
Get that can put it in 3 screws, just tilt it sideways once loose to remove old one.
You can then check your Centrifigal advance as I described, with a timing light that advances the spark. Once you know that number ensure your base is set for with Centrifigal to total 36 degrees. So if your Centrifigal is 24, set your base at 12, if it is 26 set your base at 10.
If your Centrifigal is way too high or low try one of the aftermarket curve kits, like Mr Gasket. Change the weights that should get you close to 25,26 then set base and recheck.
Now with you vac can pulling 10 you have 46 BTDC for light throttle and super cruising, great response great gas mileage etc. 46 to 48 is what you want.
Now for full manifold, I run that and recommend it highly, car runs smoother at idle and cooler at idle. Your car will run at 20 BTDC with the 10 Base and 10 on the vac can.....if hooked to full manifold Vacumn, it will be smooth as silk. If you use ported you will idle at 10 and have a hotter engine not as good idle.
In about 1965 in order to meet emissions standards just starting, the manufactures wanted to burn off more Nitrios Oxide, the way to burn that off is a hotter exhaust,....the way you get a hotter exhaust is to retard timing,....an inexpensive way to retard timing is to take the vacumn advance away from the distributor at idle...the way to take the vac advance away is to hook the vac to no vac, i.e. A vac port above the throttle plate. ...so it is an emissions improvement.
If you use ported vac everything will be the same off idle, but why do it? Who wants their car to overheat in traffic.....bad timing makes a hot runner.....
So as time permits work on this and you will be pleasantly surprised....use the two light springs in the curve kit, or a light and a middle spring.
I used two black springs today from a Mr.Gasket kit and it started at 900 RPM and all in by 3400 RPM....each Dist is a little different. But you can get real close just with a little work.
Too much timing will cause engine knock and lots of cars have way too much!
1 - 12 of 12 Posts
