Guys,
I know this has been discussed and I did look @ some older posts but I wanted to ask again. Please bear with me.....I recently purchased a completely re-done '65 Tri-Power convert. It was a frame-off that to be honest had a ton of loose bolts all over the car. They obvioulsy never did a shake-down on the car. It had been done for a gentleman who was going to put it on display and never had any intention of driving it. While I may not drive it a lot I am definitely driving it a bit. The car is now very tight and drives very nicely. The dip-stick was broken off half-way down the stick. I changed the oil and all seems good. I recently read that the car takes a 25" dip-stick. I found a "Universal" stick that works to get me a reading but certainly can't be kept in the car as a permanent replacement. Now the question (Finally).....how long should it be from the top of the tube itself to inside the pan? I want to be very certain that I am getting an exact reading. I am sure that when I checked it this weekend I was too deep inside and was not getting an accurate reading. Also, have read many times that even though a lot of literature calls for 4 quarts plus one for the filter, it is actually 5 quarts plus one more for the filter, Correct? Thanks all, very much appreciate it.
Scott...
Scott...
