I have started looking for a bracket that holds the trans kick down switch for the 65 GTO tri power.
I have seen one picture that seems shows the switch mounted to the throtle cable bracket, is this correct,
Does anyone carry the parts i need
66 was the change and the switch eletronic trans down shift switch was relocated to the peddle.
The first two years had the switch by the carb.
I just have not seen one for the tri power.
all I can figure is it mounted to the throttle cable bracket or there was a mounting bracket on the last carb.
