I had to drill out the aft bolt holding the fender on my 65. The nut is floating inside the frame and I cant find a way to access it. Ive even looked through the inside of the cabin by the air vent. I cant get any help from the Chassis Manual as well. The diagrams are no help Has anyone had this issue before? Ive attached some pics. I want to re install the fender correctly. HELP:):) please
Bill
Since that area of the cowl isn't visible with the fender hung,
"I" would make a small 3 sided cut and fold the "Flap" up/down to access the cage of the bolt.
Make the needed repairs then fold down and weld it up. The same process to access body bolt via floor pan.
JM2C
Cheers
