been a while since posted some pics- work is super busy(thankfully)- got the rear seats cut down and fit, got the radiator plumbed and the air intake done- after 4 tries cutting and welding to fit around everything, got the amps installed,and started to build the rear center console that will house the sub.I have now resolved for a spring launch date, thought it would have been this year but due to work I wasnt able to work on the car in august or sept. Probably a good thing keeping me from rushing some stuff:cheers
seats are out of an 06 gto, I had to modify them slightly:rolleyes:
the 06 is MUCH narrower so I cut the middle section out and pushed them outboard, I also had the upper bolster section removed because it was much to high. I do run the headrest and you can easily see out the rear window
