Some of you may have seen posts on PY forums about this car my buddy Brad and I bought for $400, resurrected it from a barn, carport where it has sat since 1985. Took it to a car show where it won 'least likely to make it home' and Peoples choice, lol. It made it home.
Pretty cool. I'm assuming that was made from a 4 door? Reminds me of the shorty 55 Chevy's i used to see.
Sounds like your friend got a real steal there if it is running and driving. I would definitely want to put it up on a lift though to make sure the welds are all in good shape, after all, it has been sectioned into two pieces. :cheers
From the other forum, my understanding is that this car is a real '66 GTO that was shortened way back when, when the car had little value as a collectable. Neat car!
You are correct. It wasn't made from a 4 door. The four door had a fixed angle at the C piller and the hard top had the sweeping curve in 66 and 67. The story can be found at northwestlegends.com look for the 66 Jackass gto thread
My opinion is that you should do more research on it. I would think that someone would have a very good reason to shorten a car (some sort of race series legality for instance) and in turn there may be a historical significance to it of some kind. If you can ask the PO they may give you a trail to start working on. The reasoning may be lost to history some what however.
