I have a 65' Tempest with a 67' YT 400 with 670 heads and TH400. I purchased the car a year ago and have been driving it every day since. As far as i know it is stock and now i am having valve train issues so i feel like it is time to rebuild the top end of the motor. So i will be replacing cam, timing gear, lifters,springs, rockers and push rods. I want to drive it on the street 75% of the time and take it to the strip the other 25%. So I am looking for suggestions on cam kits. I was thinking this one https://www.summitracing.com/parts/cca-k51-240-4. Please let me know if this one would be good or should i go smaller on the cam.
cam
look up the the 068 cam specs. that is a good choice. I just purchased one from a pontiac rebuilder on Ebay. fpaul is the name. I got my cam,double roller timing chain, oil pump,valve springs,lifters, studs, poly locks from him. Get on ebay punch in 068 cam and look for him. wealth of info.
That 292 Magnum cam would be real nasty in a street 400. Definitely NOT a good choice.
A Summit 2801 would probably be a decent street/strip choice, and about the cheapest thing out there. It's sorta like a higher lift version of the Pontiac 068 cam.
https://www.summitracing.com/parts/sum-2801
Next thing up from that would probably be something like a Lunati 10510312.
http://www.lunatipower.com/Product.aspx?id=1759&gid=278
Then a Summit 2802 is another step up.
https://www.summitracing.com/parts/sum-2802?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-summit-racing&gclid=CjwKCAjw64bPBRApEiwAJhG-fu4aLOTHyW3m1kumqoBBX8-RzGGxietZQw_KF_FlLQq1jbmLPSeP7RoCJdgQAvD_BwE
Here's a Crane & a Howards, in that same neighborhood.
https://www.summitracing.com/parts/crn-283951?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-crane-cams&gclid=Cj0KCQjwhrzLBRC3ARIsAPmhsnU0u54qydmvH3kgPclzar4EixRF9nyONKDNg0eySh9VIuf6FmIYCaIaAusEEALw_wcB
https://www.summitracing.com/parts/hrs-410141-12
Bigger cams will give you more top end power, but a rougher idle, and less low end torque & vac.
https://www.crower.com/camshafts/pontiac-287-455-compu-pro-hydraulic-cam-284-hdp.html
https://www.summitracing.com/parts/hrs-410051-14/overview/make/pontiac
Not offering advice, but instead, sharing an experience. I recently installed a Lunati Voodoo 262/268 in my '71 GTO with a stock 400 engine. This cam serves my purpose, but I really don't have anything to compare it to. The motor runs well and has adequate power, but I do think it is a little sluggish. Maybe not the cams fault. Good idle and response. About 17-18 inches of vacuum. This cam came highly recommended by a few who I admire and respect their advice. I have no regrets. The cam I removed was also a Lunati. High performance. Thought it was choking the engine. Best wishes with your selection.
