New to the forum and need some advice. I'm having my 67 400 335 hp engine rebuilt. I want to lower the compression (around 9.2-9.5)to run pump gas. I'm putting in the h.o. "068" cam will be installing the factory h.o. exhaust manifolds w/2.25 pipes. I have read other post about the 8 eyebrow pistons available and looks like these should not be used. Can anyone recommend the best piston to use? Any other comments or recommendations is most appreciated. This is a TH400 auto, A/C, power brake car with 2.93 non-posi rear. Just want a good pump gas motor with with the h.0. upgrade.
You might try reading thru my 400 engine rebuild post. " Crack open my 400, this is what I found" Asked pretty much all the questions your asking. 068 included and more. Breakin on mine coming soon.
Wow! Thanks for information. I'm going thru the same situation you did and this is a great help. I've got a lot of work to do. Thanks again.
"...Can anyone recommend the best piston to use?..."
Wouldn't recommend the 8-eyebrow pistons for any build.
I'd consider Auto Tec customs the best. But will probably cost $550-$600.
But, the Speed Pro forged pistons are cheaper & are plenty strong. They're just heavier & use the thicker factory spec rings. The tops are thick enuff so that you can have a dish machined into them, to reduce CR, for pump gas. Lots of guys have done this.
https://www.ebay.com/itm/Speed-Pro-TRW-Pontiac-400-Forged-Coated-Flat-4VR-Pistons-Set-8-030-w-rings/151751641964?epid=1117837845&hash=item23551a4b6c:g:XxYAAOSw-xVaFdO8
Another higher cost option is icon pistons, which have a 14cc dish.
https://www.summitracing.com/parts/uem-ic891-030/overview/make/pontiac
For rods, you can either have the stock cast rods resized, using ARP bolts, or you can buy stronger forged rods. I recommend RPM H-beams. Will probably cost well over $200 to have the cast rods resized. The RPM rods cost $400.
http://www.racingpartsmaximum.com/sae4340steelhbeam-2.html
What Big D said you can take to the bank. Ross makes great dished pistons for our engines as well. Not cheap. But they work very, very well. Helped a friend build a '65 389 with Ross pistons for a CR of about 8.5:1, and with stock heads and a Comp Cams 268 cam, it runs like a scalded dog on 89 octane. Now that the engine is apart is the perfect time to go ahead and install the correct dished pistons. You will never regret it. I built my '65 389 back in 1981 with forged flat topped pistons, and these days, can't get the fuel to run the car at the pump. It's a race gas situation, and it keeps me from enjoying the car. Do it once and do it right. You are asking the right questions here!!
