Does the z-bar not have a bushing on the arm that connects to the rod that goes to the fork? The one to the clutch pedal does and the clutch pedal itself does.
TIA
TIA
Not that I have ever seen. The rod that goes to the clutch fork will be threaded for adjustment. The square threaded block end that goes into the Z-bar just fits into the hole, metal-to-metal, and has a clip to keep it into place. Here is a diagram: 64 65 66 67 GTO LEMANS CLUTCH & LINKAGE PARTS
Im with Jim on this .... I have had several 4 speed 67's thru the years.. my 68 n 69's are the same too
all were metal to metal ,,, 67 68 69 cutlass used a rubbernsteel sleeve on the bellcrank to
pedal pushrod pivot .... but not the pontiac I have seen ... I think someone improved your setup
and drilled out the out of round holes and bushed them ...
Scott
