Hello guys,
I picked up a 67 gto with a sbc 350 in it. It also has a th350 transmission. I don't know why it was put together like this but it runs and is in great shape. Problem is I can't find a driveshaft for it. I know the shaft will probably have to be longer than the original. Any ideas or places out there I can contact that may have one?
What vehicles out there are comparable that I can grab a driveshaft from given my configuration. It's hard to determine a measurement because I have no yoke either. Thanks in advance!
Have 2 thick cardboard soap barrels with clean original GM A-body and F-body driveshafts sticking out the top of them. Usially sell 2 or 3 driveshafts a year, and thats typically when im building HD posi rears and coming in contact with guys that need a driveshaft as well. Shipping is what really hurts on driveshafts... I've always shipped in a PCV pipe & even with an acct, FedEx is expensive!
What part of the country are you in? Can possibly suggest a long time local vendor and then you can figure what center to center dimension driveshaft and if the GTO still has a bolt in axle 8.2 rear, or if rear has been swapped to a Chebby 10 bolt. Have seen it all!
