67 GTO easy headlight wiring ??
Hi all,
Thanks for any replies.
Doing final assembly on 67 GTO. The wiring harness going to the front headlights on each side has a three wire bundle-blue,purple,white.
The blue/purple go into a plug which attaches to the headlight. The white wire on each side is loose and has a ringlet on the end of it. Is this a ground? Do I attach it to the radiator support?
I would assume so but not sure because it's white or light tan.
Thanks!
Phillip
Hi all,
Thanks!
Phillip
