I can send you a picture of the harness that I made. It was very simple to do.Sold my friend. Two relays going in in the fall.
Would very much appreciate a pic of the relay harness.Relays are the way to go. I put a 6 relay and fuse box in my cougar. Use the original wires to energize the relays. It's self contained terminal block on on side for inputs and another on the other side a terminal block for out puts. Changing out the vacuum headlight door for electronic. Car stereo and power ports , igition etc. I haven't got that far on the Pontiac yet. But looks like the writing is on the wall that will happen as well.
Replied at wrong spot. Please post a pic of the relay harness you fabbed up.I can send you a picture of the harness that I made. It was very simple to do.
Great info, very thorough. Wiring is definitely not my deal so pics and schematics are very helpful. Thank you for your help and speedy reply. May have more questions when she's out in the spring. Regardless, will let you know how it went.In my picture, it shows the relay trigger wires coming in from the OEM Headlight wires, but since you'll be plugging the ceramic adapters into the OEM harness, you'll splice off of the adapter wires to trigger the relay. Try drawing it out on paper. I need to take a better screen shot of that cad picture
So am I to understand you can convert to these LED by simply swapping the housings and then using the LED inserts? without changing anything else? I really don't want to fry the headlight switch as I have hideaways/vaccum on my 68' and that switch is already a PITA.I put these in all 4 buckets on my '69. Man what a difference! With these things, at night I can see all the way into next week.
H4 Bulbs
H4 Housings
Just a wee bit of customizing was required on the high beam side. The slots in the buckets for the locator tabs are different between high beams and low beams, and these housings are intended for low beam only. It was an easy fix though. Since the tabs on the new housings are on a separate ring of sheet metal and not part of the glass like they are on regular bulbs, all I had to do was snip off the one tab that didn't line up with the bucket using a pair of sheet metal shears. Also the high beam connector in the wiring harness only has two terminals, but it still connects just fine to the bulb. I wrapped insulating tape around the exposed terminal on the bulb to cover it.
Bear did it, so it "can" be done, however, even though the LED's draw less amperage than the H4's, I do believe that they draw more than the OEM T3. So if your switch is already finicky, I would do the relay harness. It's cheap and easy to make, plus it adds two bulbs and a lot more power to your system, so the improvement will be drastic.So am I to understand you can convert to these LED by simply swapping the housings and then using the LED inserts? without changing anything else? I really don't want to fry the headlight switch as I have hideaways/vaccum on my 68' and that switch is already a PITA.
thanks
Thanks AOD, I might just try it. Need to wrap final piece of restoration though this spring. New UMI rear control arm setup with the factory braces GTOTIGR sold me from this forum (thx Bob!). Then I’ll give it a shot, at least before Hot Aug Nights. Now that she’s painted and all restored after 20yrs, it’s time to show her off. Lost out last summer with this GD pandemic. Blah.Bear did it, so it "can" be done, however, even though the LED's draw less amperage than the H4's, I do believe that they draw more than the OEM T3. So if your switch is already finicky, I would do the relay harness. It's cheap and easy to make, plus it adds two bulbs and a lot more power to your system, so the improvement will be drastic.
That being said, once you buy the four glass lenses, which accept H4 style bulbs, YES. You drill a 3" hole in your existing buckets and these will pop right in. If you're determined to not use relays, then I would try it, just know that it'll be at least 30% dimmer than it would with relays and the 2nd set of filaments from the OEM high beams.
I was glad that my 70 Vette convertible was on the road for the pandemic. I took a LOT of cruises! But the GTO will be more fun and I can now go shopping with my 78 cubic foot trunk!Thanks AOD, I might just try it. Need to wrap final piece of restoration though this spring. New UMI rear control arm setup with the factory braces GTOTIGR sold me from this forum (thx Bob!). Then I’ll give it a shot, at least before Hot Aug Nights. Now that she’s painted and all restored after 20yrs, it’s time to show her off. Lost out last summer with this GD pandemic. Blah.
