Trying to remove header panel and grill surrounds. Took out the bolts at the top of header panel, but it seems like there are more at the bottom? Can't get behind the header too see if there are any screws. Any idea whats holding it on?
You will have a support bracket from the horn brace to the lower side of the surrounds. You should be able to reach this from under the car in front of the radiator. Also the surrounds are attached to the header panel using the studs from the chrome trim on the bottom of the header.
