AC fuel pump, used, works, $20
Air conditioner condenser mounting brackets, excellent condition, with all bolts and clamp, $20
Positive and negative battery cables, in good condition, with heat shield on positive, $10
2 bbl Rochester carburetor, #7027061, $100, older rebuild, needs gaskets.
Rear brake lines, steel, $15, complete, no holes, some surface discoloration
TH400 cooling lines, steel, $5, good condition, some surface corrosion
Air conditioner hard lines, $5
Cloyes timing set, chain + gears, S371 and S305, $10.
Front antisway bar mounts, stock, complete, will need new rubber or poly bushings, $5.
Thermostat housing, original, some pitting, otherwise good, $10.
Front Disc Brake Proportioning Hold Off Valve, original, $10
All plus shipping from 47401, Indiana.
