Got a basket case that I am doing a ground up that did not have the original radiator as part of the purchase. It is not an A/C car so it has the 15" core. I bought an aluminum unit and it is supposed to be the same size but is about an inch too tall and I can't figure out why. the manufacturer says that he has not had any previous complaints. Any ideas why? The VIN numbers are correct and the core support was not modified.
thanks
it will stick up about an inch above the radiator support if thats what you mean, i believe i had to use the AC car lower rubber isolators.
