Hi again,
Water is able to get in around the gap between the rear light assemblies and the body - is this common? Should it have a seal, and if so, are these available? If not, any tips how to seal it with a sealer eg seal from inside trunk or seal externally (which may look bad).
The rear window leaks too - need to investigate that also but water is getting in trunk.
Paul
Hi again,
Paul
Yes it is commom on 67's. Talk to. MY67GTO on here. He has "the solution".
