Hey guys, I have a car that needs pretty much every panel replaced that touches the trunk opening. Im looking for guidance as far as the order in which i replace them.
My current plan is to tack in a new tail panel to and then replace the trunk floor. Then work outwards with new inner and outer wheel wells and once I get the car back on the frame, I'll do the quarters. Is this the best way to do it?
Does anyone make the inside of the sail panel or will I have to fabricate one? Thanks and I welcome all advice and knowledge.
Oh man, that sucks, I’m not sure if anyone does offer any sort of replacement for those areas, you might be in for the same road I will be headed on my 73 GTO, not much out there as for aftermarket sheet metal, I Love the 67/68 body style, sure hope one of members here can help you out.
You might want to get ahold of CTC Auto Farm in Texas or Franks Pontiacs a out in Calaforina and see if they have good sections cut out or maybe a better body for sale, otherwise locate a good metal fabrication shop that will fab up panels.
