The pads are the same AC or NONE AC.
There are 4 exposed screws across the underside of the bezel to remove.
Then you need to remove the the Glove box Liner to get to the the nuts on the threaded studs left & right of the box opening.
It's been some time since I've opened a '67 and can't recall if there is a stud on the far left driver side corner as well.
But a peek up under should tell you.
Thats it.
