So, I just bought a 1965 pontiac Tempest Custom (GTO Clone). It has a 67 YT 400 w/ 670 heads. The guy that i bought it from said it had a mild cam (of course he didn't know the specs). He did not know of anything else done to it. Hell he did not even know that it was a 67 motor until i told him. So with all that said. I know nothing about these 670 heads. What fuel do i need to run? It is a street car, daily driver. i have drove it several times already with 92 octane. But please tell me if i am wrong or if I should get new heads for the street. Thank you in advance.
Banned
Welcome to the forum.
You don't know what the compression ratio is and usually if the compression has been lowered to 9.5-1 to run on the new pump gas it is done with the pistons not the heads.
Do you experience pre ignition?
My engine is built 9.5-1 and runs good on 89 octane.
You don't need new heads to run it on the street.
No i do not know the compression ratio. Like i said i just bought the car and haven't torn into the motor. So far i haven't had any pre-ignition or detonation. I will find out the compression ratio soon
Banned
Does it run good?
No smoke or low oil pressure?
Why do you want to tear into the motor?
