1 - 20 of 24 Posts
I've tried over and over using different sources to shrink and resize photos so I could post them with just NO luck. My good friend Bill recently finished completion on his '67 GTO hardtop that he bought in 1977 while a junior in High School It has sat since 1991, and with me prodding him constantly (and offering to drain the old fluids to get the project moving) he got it done. It took about 3 years, but as you can see, a typical zero rust Calif. car. He went from turqoise interior to a parchment interior, and an auto to an m22 4 speed, but it's all correct, oem stuff that he's stockpiled for over 30 years. The interior is Legendary, and he did it all, including the headliner. The other pics are of my goats, the '65's protecto plate, etc. My '67 convertible is currently down at Bill's in the Black Widow Garage (only smashed one so far....there will be lots more when it warms up) with the engine and trans out for a makeover. I will post more photos of the process on my new,exciting photobucket site!!! I am replacing the rear main, clearance checking the water pump, and resealing the whole engine. I rebuilt a TH400, and that's going in with a GM L-88 spec Hi-stall converter. I hope this link works....
Jeff http://s1090.photobucket.com/albums/i372/geeteeohguy/:willy:
Totally jealous. For me. The plan is to paint the 66 white with some black accents. I like how clean it looks white in your friends pics.
Discussion Starter #10
Jet, Gary's convert has been sitting on those 55 gallon drums since 1980. Last month, it was hauled down to the LA area. It has been blasted, and is now in prime at a body shop. It's getting a full on resto. Believe it or not, it has solid floors and all original panels. It looks TERRIBLE, but it's "all there". The chassis was restored and put in a barn in 1980. It's an HO 360 horse 4 speed car with 3.55 gears and rally gauges. Burgundy with black gut. It should be on the road in a year or two. No, my car was a tired old convert when I bought it in '83. I rebuilt the carb and front end and drove it about 60,000 miles as a commuter, then built the engine in '88. I painted it burgundy and redid the interior in '93, and that's how it is today. It's no show car, just a nice "driver" GTO. It's never been "out of service" or restored. Just repaired. I'll post some pics of the rear main seal....unbelievable. Bill's GTO is the white '67 that he bought for $1200 in 1977. It was and is his "first car" . It's all stock and correct, with the exception of the '66 tripower on it. With the 3.55 gears and 4 speed, it screams!!
Okay....I posted some engine photos. The rear main (non asbestos rope) was missing about an inch of seal on the upper portion of the main. No wonder it was pourig oil. The bearings were all inexcellent shape, so they went back in. The new seal is a BOP Viton seal, and it fit great with no issues. It should seal FINE. Got the engine back together and painted for the most part, but am still waiting on an AMES parts order before we can stab it back in. I need the oil pan braces for the back of the pan (never had 'em) and the engine wiring harness. Needed a new water pump (put a cast iron impellor one in), and Bill insisted on new brass freeze plugs. I got over there yesterday at mid day returning from the Bakersfield March Meet vintage drags, and we worked for about 7 hours. These things are always much more work than anticipated. I ended up installing a new steering gearbox, too, as mine was leaking. Thanks to Bill, who did a ton of work on it while I wasn't there (he lives 50+ miles away) the progress has been great. He even borrowed a pressure washer and blasted my grungy engine compartment and my underchassis clean. So, another hard day or two and the thing will be back together. Got the trans back in yesterday, too. I HOPE I didn't screw up the rebuild on that, if I did, you guys will be the first to hear about it!!!
67 Basket Case Restorer
Dang, I guess you can teach an old guy new tricks...congrats on the photobucket account...:cool
The caption didn't transfer with the pic. He has a screw driver inserted 1" until it hit the "shrunken" rope seal after removing the cap...:eek: Looks more like a poor install during a previous rebuild...
Discussion Starter #13
Yeah, and Yours Truely did the install. And I wasn't drinking beer or smoking crack, either. But there is simply no place the missing portion of the rear seal could have gone. I remember the build was late at night, in my dad's garage with poor light, and I used an antique straight razor to cut the seal. Lost the razor that night, too. The seal wasn't spun in the cap, just an inch too short in the block. I don't know what happened, but it did leak shortly after the overhaul, and got worse over time. So, I think it was a bad install by ME. Mitch, I can see why the front clip is off of the Chevelle.....when the engine is out and parts start getting bead blasted and painted, that engine bay starts to look pretty sorry. If this weren't an "emergency repair", I would probably take the body off the frame and do the whole darn thing. It's tempting, all right. And one thing does lead to another! The engine will be going back in this week or weekend, with any luck, and the car will be back on the road. Even with the un-detailed engine bay, it will be in better shape than it ever has been since I've owned the car!
Discussion Starter #14
Pictures by geeteeohguy-Photobucket
Posted two new "engine-in-car" photos on photobucket.
Got the engine in and running. No leaks at all, used the BOP rear seal, and installed an adjustable vacuum advance to set total timing at 35 degrees (instead of the 44 it was at!!) The GM3-HS converter I used makes the car pull off the line hard, like it has 3 series gears instead of 2.56 gears. Drove the snot out of it, and it's never run better. It pulls like crazy. Drove it the 50+ miles home, and it was as smooth as glass at 75+ mph and has never run better. Pulling into my neighborhood, had a shudder on the 1-2 upshift at light load. No issues at heavy or WOT, or manual 1-2 shifting.....just light throttle, in "drive" upshift. Going out to adjust the manual valve in a few (I had issues with it before) and see if that helps. Ran the car last night in the driveway for about 20 minutes after the 50 m ile high speed run, and it is as dry as a bone underneath....like a new car. Amazing. It took me 29 years to fix the darn oil leaks. Now, it looks like I need to refinish that master sylinder/brake booster....the look terrible in the photos. I hope I don't have to pull the trans back out!!!!! All those "correct" steel lines are a real PITA to deal with instead of the rubber hoses I used to run......
Looks really nice, Jeff. Glad to hear the leaks are finally a thing of the past..
Discussion Starter #20
Thanks, guys. Already back in service and been driving it. Was 83 degrees yesterday, and will be the same today and for the weekend. Back on the road burning gas and rubber, but no longer burning oil (on my exhaust system!!!)
1 - 20 of 24 Posts
