Does anyone know if a 68, lemans (gto clone) convertable, uses the same crossmember as a hard top? What years will interchange??
Thanks, Duck
crossmember
just went through this about 4 hours ago with the '66 Lemans ragtop. Pulled 326 w/st300 out. Put 455 w/th400 in. I read an old post awhile back about the coupes & convertibles having different crossmember locations. that was for a '66, though. Not sure about 68's. Will do a little creative weld modification on the crossmember. You might have to do the same.
Thanks, Duck
The short answer is no they are not the same piece due to the convertible having a boxed in framed, therefore it is narrower between the rails of a convertible than that if a hardtop. Now the LeMans convertible and the GTO convertible use the same cross member.
