I am about to install a rubber hood to cowl seal on my '68 GTO but it doesn't come with directions. It came with the black plastic "T" tabs to hold it in place, but I am not sure of the proper positioning of the seal and where these tabs attach to the seal? Anyone installed one of these before and have a picture of the proper placement? Thanks
Thanks for the response. I see the holes in the cowl, but the rubber seal does not have any, so I guess I will have to make them. The seal is a triangle shape with a lip underneath with one open end. So I put the "T's" through the open lip portion and then face the open end of the lip towards the windshield? I can't photos with the proper positioning of these things anywhere.
Great thanks everyone. I even found that if you use a hole punch to make the holes in the seal for the tabs it works perfect. Sounds reasonable. I will give it a try.
