81 - 100 of 118 Posts
Discussion Starter #81 (Edited)
It has been a long time and I started feeling like this project would never come to a point where I felt comfortable driving her so a few days ago I said to hell with it and lets just go around the block... What's the worst that could happen...? No mirrors, seat belts not installed, tail light still out, no plates or registration/insurance... the list goes on and on but I needed the motivational boost and to feel her rolling again.
In the second video I came upon an issue I all but expected, I lost the prime on my fuel pump and had to fiddle with it to purge out the air. I have to relocate the pump and install foam in my fuel cell before I hit the open roads.
Now that's what I have been waiting for!!! Bad ass looking. Bad ass sounding. I just got a woody. :yesnod:
I like a guy who says "I just want to test drive it. I'll get it legal later." Done that a number of times in my youth and got caught a couple times - having to go to court on it a couple times and once having my car towed away and had to pay that nice bill. BUT, always worth a good memory, especially when your buddy is riding along as shotgun. Moral of that story was do not open up the two-fours on 450HP with open pipes while going under an overpass to impress your buddy - it alerts the state trooper sitting in a parking lot. :thumbsup:
Discussion Starter #83
I began prepping my "holey" hood for primer and paint as my search for a used replacement continues...
p.s. if anyone reading this has one or knows of a 68-70 GTO hood within a reasonable drive from the state of NY drop me a line...
I needed to test fit the hood to see if I was going to even be able to get it to close with my current intake/carb/filter setup and damn was it close! I did close it all the way and measured less than an inch clearance from the front of the filter to where the hood would have been had there not been a gaping hole... So I will probably shoot this one with epoxy primer at the least on the next nice weekend along with my Carousel Red spoiler.
I'm trying to choose the final paint and it's between John Deere Blitz Black, KemFX Single Stage Satin Hot Rod Black Urethane, Eastwood Rat Rod Satin Black 3:1 Single Stage Paint or TCP Boulevard Black - Hot Rod Flatz Urethane Automotive Flat Car Paint.
I'm leaning towards the John Deere. The depth of black, amount of sheen when both the thinner and harder are used is right on with what I'm looking for plus it's for farm equipment so I know it will hold up to some abuse. It's the only one that isn't a single stage urethane, I believe and seems to be very forgiving as a shoot in your driveway type paint as it sets up extremely fast.
[/url]Untitled by paradox_69_666, on Flickr[/IMG]
Find a Trans-Am hood scoop and fit/cut that to your hood. Should easily fill the hole and go along with your theme. VFN makes 'em in fiberglass for $120 70-81 Firebird OR, get on Ebay as they have them.
Discussion Starter #85
that could look pretty cool. I just found a used one in really good shape a couple hours from me for $250. I'll still have this one to play with and may attempt to do something like that too just for fun. Thanks Jim!
$250 seems a bit high in my book unless I needed it for my Trans-Am restoration ($125 might be a better price seeing you may have to "adjust" it to work), that's why I pointed out the VFN fiberglass one. It appears in the photo that it may have a fairly flat area outside the scoop itself which might lend in its ease to mount to the under hood bracing. It will also be lighter than the factory piece.
Ebay has one for $99 plus shipping which would be cheaper and save you the drive/gas/time. This is also the later type. You can see the shape of the outer base and the hole on the top/left is the drain for rain/water. https://www.ebay.com/i/302989067267?chn=ps
Here is a great explanation along with photos or the differences in the scoops according to year of production. Hitman's Pontiac Trans Am Site - Shaker Scoops
Where you have cut the insides of the GTO scoops, if there is any kind of gap, I would fill it in/fiberglass it to contour and then blend it into the Trans-Ams scoop to make it look all one piece molded together. Your matt black should contribute to the look. And if it were me, I would open up the back of the scoop to let cool air in/engine heat out. You will be the only GTO with this type hood - and will probably get a lot of lookers trying to figure out what you have and where you bought it. :thumbsup:
You may decide you don't need another hood. :yesnod:
Discussion Starter #87
I still may pursue this look with the Trans-Am scoop but to clarify, what I found for $250 was a GTO hood in really good shape and not just a Trans-Am scoop. Sorry for the confusion. Given that re-pop hoods cost anywhere from $550-$700 delivered I think this is a good deal for an original hood.
Agreed, that is a good price. Just check to make sure no kinks in it. The hood is long and heavy and as the hinges would develop a little rust or lose their lubrication, many would force the hood closed - until that one day when you really had to force it down and the hood would buckle or kink just in front of the hinge. Had one on one of my cars. Ruins the hood integrity. I skinned the hood to use on another hood for its scoops. :thumbsup:
Discussion Starter #89
Tail light issue found... As suspected it was a bad ground connection from the ground straps to the bumper brackets.
Since I have the bumper off and this was my only external electrical issue I will begin prepping the whole car for paint. I'm going to use a little filler where needed but mostly I will be using Evercoat Slick Sand.
Currently everything is sealed with a black epoxy primer so I think I will do a light coat of the gray slick sand and then block sand to identify the trouble spots and react to them accordingly. Depending on the severity of the high/low spots I may just use the high build primer to do most of my filling but we shall see.
Once I have the body as straight as I can get it I will seal it with John Deere Buff Primer Sealer, then hit that with a good 400 grit wet sand. After that I will take the fenders off so I can spray all the jambs and seams with John Deere Blitz Black as I will have the rear bumper off already too. With the fenders off I should be able to get into the door jambs well enough without having to remove the doors. After the jambs and seams are painted with the Blitz Black I'll get everything back on and shoot the entire car assembled.
I only just stumbled upon this John Deere paint in another forum as it's quite popular in the "Satin Black" Hot Roding community. There are so many to choose from and the other one I was looking at was Boulevard Black from TCP's Hot Rod Flatz line, and still may change my mind back to TCP at the last minute... The John Deere is an enamel and intended for farm equipment that gets abused and baked in the sun so I have to believe it's not a bad choice.
Discussion Starter #90
I'm so glad it's been raining all month... my mud was starting to get dehydrated.
Closer and closer. Tail light issue solved. Rear bumper brackets painted and rear bumper reinstalled. My wiring is all buttoned up under the dash now. I have under the dash courtesy lamps now, thanks to the complete wire harness replacement, when I never had them before, all I need are some bulbs. I think I'm going to go through and replace all the incandescent bulbs with their LED equivalents, inside and out. AMES sells a few and so does Diode Dynamics, which is a very high quality brand but also very expensive relatively speaking. AMES also sells the LED flash relays that are needed when replacing turn and hazard incandescent bulbs with LED's or you will get a rapid flash. I did this on my VW and I absolutely love the results. Most of them can be found through various different vendors other than those two also. As I wait for summer to get here I will continue prepping for paint and finish up the last re torque I have left which are the header nuts.
Road worthy to-do list:
-Paint
-Wheels/Tires
-relocate fuel pump
-install fuel cell foam
-fabricate heat shield between headers and upper control arms, I'll probably hit up a pick-n-pull and take a heat shield from some car, trim to fit and away I go.
Once those things are wrapped up I would feel comfortable getting her registered and insured and start more extensive test drives. There is still a lot more to do after that like;
-weather stripping
-sound dampening/heat barrier, interior.
-sound system
-head liner and a few other interior items
-and all the little detail misc. items that are too long to list...
It is very encouraging... I am so close to being able to take her on the road again. It was around this time last year I started this thread and this weekend will mark the one year point when I got her back from the metal shop as a complete hulk when the real work began. I only was able to work on her for a couple hours after work and on the few weekends I didn't have my boy with me through the summer and yet I was able to get her so far. I have no doubt she will be on the road this year and maybe to a couple parking lot car shows.
The saga continues... stay tuned...
Here is a Chevelle that is painted the same color I'm going with and has the same brands of wheels and tires. Differences I will have are all my trim and rear bumper will be painted. The only parts with a metal shine I will not paint are the grill edges, Pontiac badge on the nose and that's about it I think.
Discussion Starter #91
Cooling system update...
So after finally squaring away my temp gauge and sensor I was able to get good temp readings. I had been suspicious of the new 4600cfm double fan setup I was using. The system never stayed on for more than 30sec-1min. Now that I have a working gauge I was able to find out why. So between the BeCool aluminum radiator with double 1" flat tube cores, Flex-A-Lite Direct Fit double fan and BeCool coolant my system is so efficent it never needs the fans on for more than a few seconds before the temp plummets below the set point. The system has some intelligence too in that the fans turn on at 60% speed at set point and then they move to 100% fan speed if the temp increases 10degF above set point. Only in my system I have it set to come on at around 180F and a few seconds after the fans are on the gauge is reading 170F. An aside; my temp sensor is mounted in the head and not the intake near the goose neck. The thermistor for the fans is wedged in the radiator fin pack, I'm not too thrilled with this design but it works, and it's up as near to the return line port as possible. Coolant flow seems to be good too. Not too slow or too fast so I believe I'm getting good heat transfer.
I am toying with the idea of putting in another gauge to monitor oil temp in conjunction with water temp so I can better monitor the actual block temp if my coolant system isn't transferring as much heat as I believe it is.
I easily could have spent way more than I did for these two components as I looked through all the options. I think all in all I dropped $800, which includes coolant, fans, anode and radiator, and I don't see how spending any more would have gained me anything in the form or efficiency in heat transfer. I am extremely pleased with this setup and highly recommend it.
The fans were fun installing as they are universal and they assume there is something near by them vertically or horizontally to conveniently mount the adjustable universal mounting brackets to but this was far from the case in my experience. The core support does not have much in the way of mounting provisions once you wad the radiator in. It's a bit bigger and takes up all the free space.
https://www.summitracing.com/parts/flx-295
https://www.summitracing.com/parts/bci-10008
https://www.summitracing.com/parts/bci-25001
Also with all of the aluminum in my cooling system in the presence of an electrolyte and in contact with steel, installing a sacrificial anode gives me a lot of peace of mind. In the beginning of this restoration when I opened up the engine I noticed my new water pump housing/timing chain cover was pitted really badly around where the coolant passages are. I was really upset about this and had no idea the galvanic corrosion was happening so I did 10 minutes of reading and found this.
https://www.summitracing.com/parts/flx-32060
With the coolant being in direct contact with raw cast aluminum and iron, it's the perfect recipe for galvanic corrosion. I no longer have a petcock in my radiator for draining conveniently but I also don't have to worry about loosing some expensive and vital components due to internal corrosion.
Thanks for the info. Should be of help to a few. However, the info is good enough to create a new Thread. Your info may get buried and not found. Maybe repost it under something titled "Cooling Options" and in this way perhaps other members will add their set-up. :thumbsup:
The Chevelle blacked out is what I was considering as well. Of course, he stole my rim idea. I am not sure I want black anymore as I keep coming up with other paint schemes as well.
If I went black, I would black out all the chrome as you pointed out. Except, I think I would keep the lower chrome on the rocker panel so it gives the body a "visual break" from the road surface. If you did not like it, then keep it, but black it out rather than remove it completely as it will add a little "texture."
Here are a couple pics. First one I thought about. Shiny black base, but all the areas you see in white, go with matt black to contrast with the gloss black.
Shiny Black '69 has the front air dam from a 1970 Judge added.
Discussion Starter #93
Good point. I'll get some more pictures on the system with respect to installing, fabricating brackets, wiring, etc.... Which Forum would you recommend I post it to? "1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion" maybe?
Discussion Starter #94
Yeah man! I agree. I also really like the look of a front air dam/spoiler. I would love to see what I can find to get in that location. I'm not afraid of fabricating something but I have seen some 68/69's with various different chin spoilers...
Discussion Starter #95
Progress...
Electrical is 99.99% done. All is wrapped up and tucked away. The last to do with electrical is replace bulbs and find a good location for my fuel cutoff switch. either hidden under the dash or under the drivers seat. It's a great feeling having replaced the entire electrical system and have it all up and running properly.
Once I finished the clean up of the electrical I moved on to applying a topcoat to my floor pan and set the gaps on the front bumper and fenders. Now that I have the fenders and bumper where I want them I'll mark them and remove the fenders for paint. I'll start sanding and priming as soon as I can. Maybe I'll take her for another test drive first to get it out of my system before removing the fenders. I can attest to one thing... adjusting the Endura bumper is anything but easy. They are damn heavy and if things aren't marked somehow before removal, which mine wasn't... it's a PITA to get it back.
Discussion Starter #96
I started body work.... This quarter was pretty bad. Clearly something hit here and someone did a quick and dirty hammer job pounding it out. I've spent a couple days hammering and doing some light filler layering and finally have it to an acceptable point. I'm nervous hammering it any more as the metal is work hardening and I don't want to thin it out to the point of oil canning. I also lightly DA sanded the whole car, which currently has epoxy all over, in pep for final paint.
The other day I found a huge leak in my electrical fuel pump, it was about 15 years old and had too much run time without fuel to cool and lubricate the shaft seal and it finally went. I was able to find some replacement seals and got that back up and running, it also quieted the pump down a little... go figure.
In other big news... I finally pulled the trigger on all of my wheels and tires. I think I read every forum out there on tire size and back spacing on GTO's. Even still I am terrified I will have an issue with fit and then need to try selling mounted tires and wheels. I intend on making a separate post if I am able the get a good fit with this setup as I know there are a lot of people asking the question.... how big can I go?
This is the exact combo I will be mounting...
Discussion Starter #97
I finished up the quarter repair. next is removing the passenger fender and hammering out the couple dents you can see in the below images. It is not perfect, only replacing it would have accomplished that, but it is so much better.
I installed more foam in my fuel cell so starving the fuel pump should be a thing of the past.
Also.... She got to try on her new pair of shoes!!!!! 235/60R15 Cooper Cobra's on Aero racing wheels; 58 series, 15X8 with 4" B.S. So far so good. I love seeing the Wilwood aluminum hub protruding through the center! I need to put my jack under the lower control arm, jack up and actuate the suspension in that corner and turn the wheel to the extremes to be certain I'm not going to rub. Then I'll put the old wheel back on until the body work and paint is done. I'm still a bit nervous but it looks really good. Going from 225/60 to 235/60 made a difference in height too. She was a bit low before with the 3" drop so this should give my cross member and headers some breathing, about an additional 0.5", room from the road.
These wheels require 45Deg chamfered lug nuts so I will get a set of them after I increase the lug studs from 7/16" to 5/8-18".
Discussion Starter #99
Great idea Jim for the rears for sure! The front's will have my nice Wilwood aluminum hubs protruding through and they look awesome but the rears definitely need something.
Discussion Starter #100 (Edited)
Biggest tires I would fit in my GTO on 15" wheels
All four new shoes are here and I have completely tested the fit. All is well!!! I can't imagine trying to squeeze in any more tire in the back or front. In the front with the wheel jacked and completely unloaded I turned her through the stops and had only one minor interference. It was in a condition that if I ever had the car in a situation where the wheel would see this state while driving... Tire rub would be the least of my concern. The rub happened with the passenger side at the front lip of the fender at the bottom corner. With the wheel completely unloaded and the steering turned to the stop, that fender corner touched the tire. Again... if I'm driving and have the wheel locked to the left and the wheel is completely unloaded something went horribly wrong.
The fronts are 235/60R15, wheels are 15"x8" w/ 4" B.S. Any more B.S. in the front with a 15" wheel and the wheel would be contacting the steering tie rod where it connects to the steering arm on the spindle. Any less B.S. and I would certainly be rubbing the fender in a couple places.
The rears are 295/50R15 mounted to 15"x10" Aero wheels with 5.5" B.S. The tires are about .5"-.75" from contacting the frame/inner wheel well with the wheel jacked up into the pocket to the point where the opposite wheel was lifted off the ground. Again, I feel I'm safe there. Also the rear wheel never came close to contacting the outer wheel/quarter lip. This new suspension (complete BMR package) helped a lot with this due to it be so incredibly stiff, even if the wheel was too wide I don't think I could ever load the rear wheel enough to raise it that high.
So a huge step forward and a huge sigh of relief. I was so nervous this setup wasn't going to fit and I would be stuck trying to sell them or make them fit somehow. I was prepared to roll the fender and/or rear wheel well lips but I am happy to report I did not need to do so.
FYI... the rear wheel/tires weigh 54lbs and the fronts weigh 47lbs.
