Can anyone tell me if the sensor I have circled in the picture is the temp sending unit for temp idiot light on a 68 GTO. The light does not come on when I turn the ignition key like the “gen” and “oil” lights do so I want to make sure it’s working. If that’s it, any advice on testing it?
it looks like a gauge style ,,, I thought a lite had the tall sender...
just ground out the wire connector and turn the key on they work of a ground
or your bulbs bad ?
Scott
or your bulbs bad ?
Scott
Thanks..... but what do you mean “ground out” the wire connector? Just disconnect it from the switch and run it to ground?
