I recently got a new 19 Pontiac Beaumont, which is a Canadian only car... but it has a 69 GTO dash in it. The car needs some serious dash work so I removed it and going through it piece by piece. I have ended up with a question.
I cant seem to get the Gauge bezel out. Is there a trick to it? I have removed the 5 nuts (three top, two bottom) and it seems like it should slide out backwards, but it wont budge. Seeing as a new piece is 200 bucks, I'm hesitant to pull on it too hard.
This is the piece I am talking about:
Thanks in advance for the help!
Yeah, there is supposed to be three screws in there... but on mine, a lot of these cars it seems, the person to own it last didn't bother to put them back in so they are not there. In all honesty, I likely wont bother replacing them either. So there are no screw left... It is just not sliding. I will work at it and see if I can get it out. Thanks!
I know that I'm late here, but just joined the forum. I recently removed mine and there seemed to be some tacky type of sealant that was holding this in. Probably to reduce rattles, but if you work at it, it should come out. there are no other fasteners
