1 - 16 of 16 Posts
I have the correct water pump, and pulley, the 2.5 inch spacer (535253) and correct balde ( 9791346) but the spacer bottoms out on the pump snout before its on far enough to seat the pulley against the pump snout? What am I missing here? It appears that the snout isn't going into the spacer far enough? Thanks
Is that where my bubble gum went ??
is there a burr on the bore of the hole ?
how fa r out does the shaft protrude thru the fan mounting flange ??
pics of your water pump snout??
The bore of the spacer has what looks like a sleeve about 1/4 of an inch in from the end of the side that slides over the water pump snout that's preventing it from going on far enough to seat fully
My mistake. I thought it was a sleeve but it looks like it was not bored deep enough to the correct I.D. it only needs to be about .080 deeper to fit properly
wow
that shaft is stickin" WAY out there somethin doesnt look right
is that a new AMES repro ? I dont remember seeing one with that clean and sharp casting number
how does your pulley line up with the crank ?
wonderin if the shaft was positioned correctly on assembly ?
wow
x2, seems way to long on the stick-out. Shorten with a die grinder/cut-off wheel and polish up with a grinder. If you drill the spacer, you may oversize the hole or even offset drill it - unless you can chuck it all up on a drill press. You don't want any vibrations as the pin/hole should be tight.
I agree. I only need to remove about .080 from either the pump about, or run a 5/8 end mill down into the spacer an additional .080. thanks guys
Discussion Starter #14
I thought I bought it from Ames, actually it came from Inline tube. Probably the same part from both vendors. I've had great luck with both companies. I contacted Inline well see what happens
I would call an Ames tech. That water pump definitely isn’t right, I have one of these on my car and it doesn’t still out like that
Discussion Starter #16
Thanks, actually it came from inline tube. I contacted them and they are checking with the manufacturer. Hopefully have an answer this week.
1 - 16 of 16 Posts
