Hi all ' I'm new to this forum and need some tech help! How much hp could I put through my 69 gto 10 bolt axle running on standard wheels and tires?
Welcome to the forum. How much hp? Believe you mean how much Torque. How much will depend on the style of rearend & how the rear is torque loaded.
-Near flawless condition A-body HD Safe-T-Track Pontiac 8.2 10 bolts have been run routinely down into low 12's in the 1/4 mile on PolyGlas & Wide Oval G70-14's, Pure Stock Drags & other venues. Near 450 gross hp/3750-3800 lbs with driver.
-In lightweight early RA Firebirds, a few well prepped Pontiac HD 8.2 STT rearends have been known to live down into the high 10's on slicks.
-With the small pinions of 3.90, 4.10, 4.33, & 4.56 Pontiac 8.2 gearsets, the nodular iron center housing incorporated in the special HD STT rears helped minimize pinion deflection. Pinion deflection is what will eventually take out a gray iron 8.2 rear ESP when built with a small pinion & thick ring gear & subjected to repetitive hard launches. The standard duty 8.2 axles just like the gray iron standard center housings are both a huge weak point.
Have repeated this so any times, but some don't get it. Unfortunately, the vast majority of Pontiac 8.2 rears are not HD Safe-T-Track rears, less than 1% are, instead, the typical 8.2 10 bolt consists of a weak gray iron 8.2 housing with standard duty axles. Having picked up the pieces from way too many blown up gray iron posi 8.2 rears, as a differential builder, it's just much easier to not throw waaay over a $1000 into "upgrading" a gray iron housing 8.2 rear with Moser axles, new gears, & a Auburn Pro Series or Eaton posi carrier. Maintaining or building a putt-a- round cruiser, the gray iron 8.2's can live a long life. Attempting to repetitively throw 100-200 more ft lbs of torque at the R&P in the weak gray iron housing, than what this differential was designed for, the limit will be reached even in a 3700 lb A-body that can only 60 ft in the high 1.8's on bias plys.
