1 - 9 of 9 Posts
When I accelerate quickly gas leaks out of the tank at the back behind the license plate. I've tried different gas caps and it still leaks. Not drops of gas but a stream. I probably lose a gallon of gas out the back for every full tank. Any suggestions?
Check to make sure your vent is connected properly. There should be a flexible hose that connects to the side of the filler neck and connects to a vent tube that goes up above the filler neck, makes a loop, and comes back down. Losing fuel like that on acceleration just about has to be coming from one of three places:
1) Around the gas cap.
2) Through that vent.
3) The filler neck itself is leaking.
I know it's coming from around the gas cap & I've tried a vented gas cap & I have a non-vented on it now. It still leaks no matter which one I use.
The caps I've tried were new. Not 100% sure the filler tube is flat. But I can tell it's coming from the bottom.
These are photos on my '67 vent tube. If you have one, maybe the hose is oof? That would explain it. Very hard to see.
My car did the same thing when I first got it. It was the vent hose. Make sure it loops up above the filler neck and it doesn't have a hole in it.
1 - 9 of 9 Posts
