Hi Guys I have a 69 gto that my speedometer is running about 10 miles a hour to fast My output shaft has 18 teeth metal gear my what I call cable gear has 38 teeth I went to a calculator and it said I need a 44 tooth cable gear so I bought it and then I needed to change the housing so I bought that now here is my problem I put everything back together the cable gear wont move I have in and out play so I know its not tight any where when I loosen the bolt it starts to turn I measure the OAL withthe gear in it and its the same as my old one I just dont know what wrong maybe someone had this problem any help will be greatly appreciated
