Ready to install the rear trailing arms on my 69. I forgot to photograph where the two odd bolt/nut combos go. ( The ones with the flanged head and washer). I'm guessing they go on the front lower mount to accommodate the braces that are on the judge.? Am I correct? Nuts face inward or outward? Thanks.
Front of rear lower control arm, the bolt goes in from outside of the frame.
When removing this bolt, one can use a 6-8" long 1/2" drive extension with 6 pont socket, will help the bolt guiding its way out.
